How do YOU fit oversized wire in push terms...
  • 5
put bolts on the box. Run leads from each terminal to sep bolts and on outside of box use ring terminals and wire it up how you may need.
This. Most subs that have push terminals have a bolt that attached the terminal itself...you can actually attach an 8g ring terminal to that bolt and run it to another bolt that connects the outside of your box to the inside. I'm using 10g speaker wire with 8g ring terminals on it so I can do that same setup.
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
283
Volvowith18psi
Volvowith18psi
Butler, PA
bhsdriller
    May 31, 2024
    May 24, 2024
