How do you extract youtube music to CD and enjoy it on your car.
Betty0920
CN
Here I have a way to extract youtube music to CD and enjoy it on your car. Hope you enjoy it. You can search "flv to cd" on google if you are interested.
CD is a format that uses raw 16 bit 44.1 kHz encoded audio signal, and .cda as the file extension.
To extract audio from FLV video to MP3 with Moyea FLV to Video Converter, what you need to do with the system requirements is to install Moyea FLV to Video Converter
It contains a free FLV downloader, It will be downloaded video from youtube,Google Video, Myspace, Metacafe, Dailymotion, iFilm, Music, eVideoShare, etc. off to your computer's hard drive in flv format
Import FLV into the Converter
Once Moyea FLV to Video Converter is installed, launch the Converter
Click on the "Add File" button on the tool bar to import your target FLV files into the conversion file list. Moyea FLV to Video Converter has been embedded with the proper codecs to avail you to add different FLV files into it, and thus you do not have to install extra codecs or plug-ins to do this.
Select output format
Click on "Settings" to select the "MP3" file format for the Export Type:
Besides controlling the export type of the audio and video, you can also change sample rate, channel and bit rate for the audio.
Don't forget to select an output directory in this step.
After this, you can click on "Convert " button to start extracting the audio to MP3 in the generated output file, then you can burn the converted mp3 to your CD.
just a //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
FLV video\audio is super compressed. so the sample rate can not get any better than the source material- which is usually garbage quality at best. converting to MP3 should be the end of this process because you can not downsample to FLV or MP3 (both compressions of lossless WAV format which is raw 16 bit 44.1 kHz, CDA is a new file format that can have copyright bullshit connected to it) because once the file is compressed and the quality is dropped, you can never magically reverse the process.
so putting it to CDA or WAV format after you convert to FLV or MP3 is just a usless extra step unless all you have is a CD player that does not support MP3 cd's - and that is a feature on 90% of stock vehicles even last year.
but thanks for the informative first post!
cliffnotes
so unless all you have is a CD player without MP3 support, skip the last part, just use the mp3. it will sound terrible so i hope you dont have a good stereo.
Thanks for all the above posts,
I will consider it.
If I want to use the Moyea FLV to Video converter, I will first try its trial version before i order it, //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If someday the compressed staff has the quality of the source material,,,it will be perfect....but now, we can only try to get a better compressed quality,
I also know a lot of online converters like vixy. And I used them for a time, but most online ones are not as steady as downloaded ones. And things are the same to the quality of the audio.
Betty0920
Betty0920
CN
Betty0920
