j3bus2k3
Si vis pacem, para bellum
werd...probably... had it as long as i can remember. it chews through 3/4 mdf like its not even there.
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gifOn time I used a drill to cut out one piece it took 2 hours.
not to get off topic here. but although i have a brad nailer and use it on every enclosure, i have to give props the the screws because by the tests i have done even after the wood glue has dried the wood screws actually still hold the wood together with more strength then just brad nails and glue alone.No more BS pre-drilling/screwing, now it's just test fit, slap on some glue, clamp in place and pop in a few nails....
i just look at the sheet of plywood, and it cuts itself out of fear.
Assuming your using a "Wood Glue", you let the glue set correctly and the cutts are straight, there should be no need for either screws or braid nails other then to help hold the peices while the glue sets.not to get off topic here. but although i have a brad nailer and use it on every enclosure, i have to give props the the screws because by the tests i have done even after the wood glue has dried the wood screws actually still hold the wood together with more strength then just brad nails and glue alone. but yeah brad nails are way easier then screws.
