(How do you connect a Battery Isolator??)
depends on how you want to control the relay. the ignition wire will connect the battery when the car is on. yes, the red ACC wire on the head unit is an ignition source. note if you have a >2000 GM Vehicle, you can't use the Class II Data Bus wire as ignition.
There should be other ignition sources in the engine bay.
Great! Is it okay if I use the same wire coming from the ignition source on the isolator to power my amplifiers also. Itll be conveinient because my isolator will be in the trunk near my ampifiers and auxilary battery...
swollen_cu
swollen_cu
New Orleans
swollen_cu
