how do jl audio amps work
since the sub is 4ohm and the amp is 4 ohm
plug the (-) to the (-) and the (+) to the (+)\
be sure to turn the gain down a little as not to blow the sub
since the sub is 4ohm and the amp is 4 ohmplug the (-) to the (-) and the (+) to the (+)\
he's got a svc so just took postive from the sub to the positive on the amp and then same with the negatives. the amp will be running in 4 ohms. and since the amp will over power the sub slighty u should turn the gain down some. what kinda sub?
jl amps have a line of resistors called the RIPS system. the 250/1 will supply 250 watts rms at anywhere from 1.5-4 ohms. The bottom line of the R.I.P.S. system is: Optimum power, at any impedance between 1.5 ohm and 4 ohm per channel, at any vehicle voltage between 11V and 14.5V.
Do note that the amount of current that is drawn when the voltage drops increases signifigantly. You need voltage and current to make output. Drop the voltage, you have to raise the amount of current drawn to keep the output the same.
  • Locked
COMPLETED Arc Audio Amps
Arc Audio Amps I am selling. KS300.2 - $200 OBO KS300.2 - $200 OBO KS300.4 (Not Pictured) - $250 OBO X2 2500.1 - $950 OBO Located in...
A Link would be very helpful. Id be interested in taking a look at some gear
57
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
222
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
defiance
