How do i wire to .7 ohm?
can anyone draw me a diagram of the 2 subs?
If you must have it @ .7ohm then follow the diagram I posted above. 1 sub per an amp. It is not possible to wire both subs to .7ohm on the same amp. You would have to settle for 1.4ohm load. which would also be the diagram I posted. Except, that you would run the wire on the bottom + terminal across all 4 of the series circuits. As well as Wiring all of the - terminals at the end(top of pic) of each parallel circuit together.
Linkz - the first diagram you posted would result in a 1.4 ohmload.
You cannot acheive a .7 ohmload out of a single QVC 1.4 woofer. Unless something is going on completely wrong in my heado n Christmas morning, but I'm fairly sure of it.
4vc of 1.4ohm
2vc wired in series(x2) [1.4*2=2.8ohm]
the pair of 2.8ohm circuits wired in parallel.
1/(1.4*2)+1/(1.4*2) = .714
this is a parallel circuit with 2 series circuits inside it.
thekidrock
thekidrock
San Dusky, Ohio
thekidrock
