How do i wire to .7 ohm?
2vc in series x 4 wired in parallel will yield 1.4 ohm
4vc in series x 2 wired in parallel will yield 0.357 ohm
all in series would be 11.2 ohm
all parallel will be 5.714 ohm
for 1 woofer
2vc in series x2 wired in parallel will yield .714 ohm
all in series would be 5.6 ohm
all in parallel would be 2.857 ohm
Your best bet for .7 ohm load is to use one amp per sub.
You can't do it...Just like trying to wire a pair of 2ohm DVC subs to 1 ohm, it can't be done with a single one of those subs on one amp (you could do it with a 2-channel amp though, just run two coils in parallel off of each channel)
This should help. Please ignore how shitty looking it is. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
edit: Opps! Forgot my ground. Re-uploaded.
can anyone draw me a diagram of the 2 subs?
If you must have it @ .7ohm then follow the diagram I posted above. 1 sub per an amp. It is not possible to wire both subs to .7ohm on the same amp. You would have to settle for 1.4ohm load. which would also be the diagram I posted. Except, that you would run the wire on the bottom + terminal across all 4 of the series circuits. As well as Wiring all of the - terminals at the end(top of pic) of each parallel circuit together.
thekidrock
thekidrock
San Dusky, Ohio
thekidrock
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
