How do i wire this? (Flipdown Monitor)
2002XLT
Thats right bishes...
not sure how i need to hook this up, there are too many wires!
its a KEC 10.4 flipdown monitor.
There are 2 sets of wires, one has the AV inputs, then 2 blacks, 2 reds, a yellow and a white, and a seperate red and black.
then there is another set of wires that has a red and a black wire plus what looks like it used to be an AV cable that was cut, then has a red, black and white cable that has clips at the ends.
i know, its a shitton of wires. lol
And yes its used, gotta test it before i can sell it.
well, usually the av wires are yellow and white.. and power wires black and red.. but if you have 6 of them who knows. unless you know how to take it apart and can determine what the wires are connected to.. the main power wires should run into a transformer or capacitor, and i'm sure the av would just go into a circuit board. your best bet is to keep searching the web for a manual of some sort... even if you can't find the exact model something similar by the same manufacturer might work.
good luck
yellow = constantred = acc
black = ground
white = domelight
so which ones go to power and which goes to ground?
i tried hooking up all the red wires together and all the blacks together and then putting them to my battery and i dont think that was right...
2002XLT
2002XLT
H-Town, TX
2002XLT
