how do i wire my amp to my subs
  • 2
ok so for three you are gonna series the subs and then parallel them together @ amp
so subs will be @ a 1.33 final load // now that amp is a 2hm stable amp it may or may not run @ 1.33
the safer solution will be to run just 2 subs then you have the third as a spare
either of those options will be wired like this
remember if you run just two subs you will need to baby the gain cuz it is rated for 2k @2ohm
yeah, it'll be hot but off. Just like your tv when it's plugged in.
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
matt.pitts
matt.pitts
newfoundland
dappa5
