how do i measure a sub???
  • 2
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
812
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
502
541
bry_mo
bry_mo
u.s.
SKMexiFry
