How do I get an aftermarket radio with honda lane watch?
  • 2
ccapital83
NY
I know pioneer radios the nex line advertises having dual camera inputs but will that work with the second camera my Honda Civic side view mirror? I'm dying to replace stock head unit but don't want to lose my side view lane watch camera.
As long as you have a way to wire it into the camera connection it should be fine.
Just like many backup cameras they were not specially made for the radio people buy, but are capable of being used anyway.
So the radio will know to turn camera on when I turn in my right directional like my stock radio does?
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
652
Yellow wire is generally memory/Access(Constant). and Red wire is generally supply that works off ignition/on/off
You cant go wrong by adding anything to improve sound quality
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
ccapital83
ccapital83
NY
ccapital83
    May 12, 2024
Brendon Jenness
    May 11, 2024
