How do I Get 14v output?
Turn your car on //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The amp puts out more than 14Vac from the power supply.
You want the 14V from your alternator.
If its a GM you will only see about 13.8V not the 14.4V like most cars
Very good point. Most GM's have an idle voltage at about 13.8-14.1. I have a 99 tahoe and i get 14.2 on a good day. i also have a big battery and a H.O. alt. Import cars have an idle voltage of 14.2 + some times high 14's. If you want the 14.4 volts and idle and have the amps from the alt to back it up you can get exteral voltage regulators.
Well when i put it on a Voltmetre...it read 12.5volts..
I got a bigger battery also..1100 Cold Cranking Amps.etc.
It is a 91' Mazda B2200..
Its Been a while,i think the truck was Off..
I Also Jus wanted to Ask..Why is there Sumtimes a Buzzing sound from the Subz at Low Volumes,then Sumtimes when i turn the volume right off they sumtimes are little sounds?
there ya go.
Start er up and you should have the voltage you are looking for.
The buzzing could be the ground, the amp itself or some interference that the RCA's are picking up.
It could be the H/U also
Besy way to eliminate the RCA's,H/U would to just unplug them and see if the noise is still there.
Does anyone kno what the Omh is On the Power Reference Pr-124 Subz?
im guessing 4omh??
Im Soon gonna upgrade to Some M3's..i dont kno the Omh on these either.
Memphis420
Memphis420
Canada,BC
Memphis420
