how do i check voltage?
get a DMM put the positive lead to the positive side (battery, amp, etc where ever you are checking) put the negative lead on the negative side (again battery, etc, etc) and set the dmm to DC Volts. If the car is off it should show somewhere around 12.6V, with the car on it should show around 13.8V.
yep it should
12.6v and 13.8 are with the system off //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif if you are dropping below 12v with the car on and system playing you need to do something to get the voltage up quick.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
blimpthepimp
blimpthepimp
spring hill
xShoWTeKx
    May 18, 2024
    May 18, 2024
