How come my CVR's aren't punching that hard?
Do THIS::: If your not gonna keep the amp for life, wire em to 1 ohm and out your gain just under half way. NO bass boost tho. Maybe 15% bass boost max! DO NOT GO OVER ON THE THE GAIN!
Oh, and don't clip the amp too much, either;)
how do I wire amp to 1 ohm and is it possible to wire 2 dual 4 ohm subs to 2 ohms each?
I must add that IF you gonna wire that amp to for a 1 ohm load, check for heat on the amp. It WILL get hot about 45+ minutes of full tilt. Then, just turn that shiit down!
Also, set sub level on your HU to "0" - Important!! And, DONT go past "1"
This is for where I told you to set your gain at (that's if your HU is 2 volt pre-out??) Mine was. DOUBLE CHECK THAT! If it's more than 2. volts, turn the gain a lil lower then where I told you to set it at.
yeah my head unit preout is 2v. so how do I wire it?
You can always tune your subs at sub bass+ at 11 or so and be fine with the setting at that level.
I always tune my subs with +11 sw level or so just incase some knuckle head borrows my car and turns it up =]
Jer510
Slap Addict
Jer510
Oakland, CA
SicAudio
