how close ............8x 12" subwoofers
sinosic
Idyllic Enclosures
4 subs up 4 subs down firing towards each other. how far apart can they be? 2 or 3" to close?
sketchup not anywhere near to scale. the hieght is way off. there is a back piece of mdf to the smaller sub box...if that makes sence. sealed no port.
i will have to glass the trunk floor to get as much volume as possible. mini wall kinda, i can go all the way up to the back of the back seat. the back seat would be down. i dont wanta hear "theres not enough room for 8x 12s." the trunk is big, and as long as the volume is sufficient it will fit. i need to know if anyone has done subs firing into each other and if 4" is to close.
check with the dude running all the 18" nightshades, he's firing them into eachother in a square. he might have some info. there is a build log on here i think, theres one on SSA for sure
also, ive seen a setup with 4 15"s ported firing into a small chamber like that (minus subs on the top firing down). it was sort of a loading chamber. absolutely slammed the lows. but im not sure how subs firing from bottom AND top will work out though
link?
sinosic
Idyllic Enclosures
sinosic
roseville,ca
sinosic
