How can I increase SQ from 12" L7?
loudfivepoint0
I have been a little disappointed with the L7's SQ since I got it. Here lately it seems to have gotten worse. After I installed a High Output alternator and upgraded the big 3, it seems worse (i'm thinking my amp is getting more voltage hence more power, and that means its giving the L7 more power than its rated at) The L7 is in about a 3.4cu. ft box tuned to 37hz (i think). I adjusted the amp to give it a little less than 750rms but now I think it may have increased to 800 or so. I can't adjust the amp correctly because my voltmeter is broken. I already have bass turned to -2 on my hu and that helps some. Any other little things I could do?
woah nelly. 37hz for SQ is WAY too high.
also, if you want it turned down a little- assuming your gains are set correctly. turn the gain down.
try and tune that box to more around 30hz and it will sound much nicer. PM Jmac and send him $10 via paypal, and he will design the best SQ box you could make for that sub. but you gotta give him the details and all.
i had a guy already build this one, it was moe lester from the forums here. If i get a new box, i'll probably get different subs too, just because i'd want a total change. its incredibly loud, which at the time thats exactly what i wanted, but now i'm gettting more into sq.
L7 is not at all a sq sub.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
No shit sherlock...
he wants to increase the SQ in his install of the L7...and asked how...
My suggestion is...
You said you already have ur bass on -2...just zero it out. Then build a large sealed box...the sealed box will have better SQ...it takes some space for the L7's sound good! So...go with 3-4 cubes sealed...peace
NG
No shit sherlock...
My suggestion is...
NG
He should buy a new sub for sq, sherlock
WHAT DO YOU NOT UNDERSTAND?!?!?!?!
He doesn't want an sq sub ....
SHERLOCK
Like i said above...he has this sub....he owns it...it is in his car. Do you not know it's all in the install?!?!?!?!?!? Therefore...he would like to know how to increase the SQ in his current setup/situation...refer to text under the name, it's been up for about a week now...
NG
Actually I've seen L7's in SQ comps just for your info , also like NG said its all in the install wrong install can mean shitty sounding system. Had to drop my two cents my pockets are full cant hold any more change lol .
SHERLOCK
NG
CHILL OUT DUDE dont have a hear failure. I misunderstood what he said, he said he was getting into sq, so i thought that he may of meant a system change sometime in the near future, if he was going for all out sq. Dont kill me in my sleep psycho.
Ok, they can have great SQ, but the enclosure is what is killing you. Want more SQ, yet have some bump, do a 2.25 SEALED box...that will sound soooo much better...yet still have some bump you wnat for daily. Sealed boxes are very easy to make as well...almost any Sherlock can build one. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif j/k to everyone, no offense, had to add to the remarks.
:fyi:WOW, you might want to chill out about going overboard. Also, do you speak english?!?!?!? If so...please rephrase your next reply...this might help you out too...
NG
loudfivepoint0
loudfivepoint0
Hot Springs, AR
ngsm13
