How big of a cap?
If any thing caps will make your lights dim more. Because think about it how does a cap work??? When there is a large enough draw the cap discharges (discharges fully in less than a second) then it recharges, Thus adding another load that the electrical system has to charge. So theoretically a cap can worsten an electrical system
oh but i dunno i would have to get the Big 3 done first anyways it dimms less in the cavy for some reason with the cap on //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you get the alumpro series 5 farad your set...Usually need 1 farad for every 300 watts. Alumapros 5 farad is nice because it's consantly sending out power to your amp. It doesn't discharge and then recharge again....
Spite what other people say I find caps helpful.
I find that it helps when the sub is pounding. Gives it that little extra that you need sometimes. But if you have a large enough amp you shouldn't even need it period. In my case I do not so it does help the sub in some cases
As for the electrical system, by plain logic, it can not help the electrical system of your car.
READ GOD****IT
The bottom line is that if your alt isn't big enough to satisfy the regular demands put on it, no ammount of batteries, caps or a combination of the the two will keep it from dying and will actually cause it to die quicker. Batteries are only of real use when the system is run with the car off. Caps have a place, but are rarely used in the correct situation. The only time a cap might be of use is to eliminate the quick voltage drop caused during a musical transient when an alternator that is big enough for the system is upping its current output (the change from 50A output to 100A output is not instantaneous). This will reduce the dimming of lights in a system that has an adequate alt.
Batteries have tons more capacity than a cap, yes, but they only supply that current at their discharge voltage which is usually in the neighborhood of 12V. Since it is the transition from the alts working voltage (usually over 14V) and the battery's discharge voltage that causes the dimming of the headlights, a battery doesn't do you any good. The cap begins to contribute current as soon as the voltage drops below the normal operating voltage of the alt. Since you only want the current for the fraction of a second it takes for the alt to catch up, total capacity is not that big of a deal, but the bigger the cap the smaller the drop in voltage in the mean time.
This is also only a consideration on a daily driver system. If you are looking for an SPL comp type system, the cap is a drain on the electrical system after the first fraction of a second. This is the main reason that you see SPL vehicles with tons of batteries. The batteries are the primary source of current for the system.
SKyleS
SKyleS
Canada
helotaxi
