How bad is this?
ehh is this REALLY bad for the sub???
it sounds pretty good and it gets pretty loud(jmo)
i mean if its gonna fvck my sub up then ill change it but idk
btw what can the se12 handle daily? (rms)
that amp is great for ur sub...the rockford one...as for the amp ure using now...bridging it is the bst option....ure amp will roughly do 300wrms at 8 ohms bridged and thats still quite enough to get loud....if u plan on buying the rockford...go for it....but sometimes its good to get a bigger amp incase u plan on upgrading...as for bridging...
it should state it in the manual...
I don't know what's wrong with the set up now. Leave it how it is. In order to avoid sending conflicting signals to the diff VC's (as would occur with stereo sound) go into your HU options and set your sub to MONO. Or, if you can't find that option. Go pull the red RCA off your amp.
leave it how it is, no need to change the amp and theres nothing wrong with running a amp in stereo to your subs. If you do decide to rewire the sub for 8 ohms you will get the same output you get now. No need to change it though as far as i'm concerned. You may want to check the gains though, maybe their too high if your smelling glue but again if its a new sub its just excess glue burning off.
johndoe1234
johndoe1234
Mesa, AZ
Safe_Cracker
