how am i gonna do this?
i dont know anything about amp wireing kids. wireing a kid to an amp doesnt sound good but i guess it helps with depression
what a wasted post //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
im sry u had to read that... now i think spliters would work but im not sure if u can only use them with mono amps or if u can mix the kinds of amp ( ie.. mid amp and sub amps) but u probly can.
also a quick fix could be a deck upgrade? what deck do u have now?
or buy a cheap in dash eq... i used 2 have a clarion 5-band... and i just installed a planet audio eq in my dad's car... his radio has one set of preouts... and that preout goes to the main input of the eq... then the eq has a front...rear... and sub preout... plus an auxillary input... and has sub control... frequency.. and other knobs lol... u can get one for less than $50 and that's prolly the easiest way besides a deck upgrade
good thinking, i didnt even think about an eq, mainly because i dont use them... but yea
I'd vote against the EQ. For one, the y-splitter would be about 10x cheaper (I think they are ~$4 each at radioshack). Second, a cheap EQ will probably do more damage than good.....especially when you're only using it for it's added preouts which could be accomplished in much cheaper ways (like y-splitters).
i had a cheap legacy 11 band for a while and loved it..exept for the fact i had alot of interference....i was thinken about the 7 band clarion from ike sound for like 52 bucks...but idk
go to car stereo one or tas electronics and they should have everything you need. in addition to using a y-splitter on the outputs of your deck they also make an adapter that converts your speaker leads into an rca connection which comes in helpful if yourusing a factory deck with no outputs.
gonzkid
gonzkid
Toledo, OH
bonesninja
