well, you really need a meter, honestly. sure, the rcas could have been melted by the floor-board, but then again, a bad ground contact will force the amp to try to ground through the rca's. if you had a good ground, then the ground section of the rcas could be wide open exposed to bare grounded metal, and you would get nothing but poosibly a little noise. also, make sure your head unit is getting good ground as well. generally, if you have a bad head ground, it will then find ground to the antennae coax shield and give you some noise, but it may be possible there is a poor contact there, too, especially if the amp searched the head for it's ground via rcas. that could cause a problem in the amp. most of this is un-common, but if you moved the grounds for the amp, and the heat moved, then there is the problem. i know you say it's good, shinny connection, but you should make sure the terminals are crimped down to the bare metal of the wire, and sanded both at the frame, and the terminal contact points. i have seen some heat-shrink residue insulate large cable eylets from making good contact, and you could not even see it untill you started running some sand-paper across it. really, some readings are going to be your best bet, or you could just look at it all day long and guess. you can get a cheap craftsman or other brand for >$35 and you can use it forever......
