Hooking up subs in J30
RcRacerDrew
Im hooking up a stereo for a freind in his 96 Infinity J30. Were using his stock headunit so I used a high to low converter off his stock infinity system for the RCAs but where do I run the remote wire from? Will any 12V source in his trunk work? Is the turn on a 12v pulse or 12v constant? Thanks!
always use a 12v constant or else your amp will shut on and off as the signal pulses.
also try taking the turn on from the power ant turn on lead at the ant in the trunk unless it's the type that shut's off when the cd section is engaged, if that's the case find the factory infinity amp and use a dmm to find the remote turn on lead to it and tap in there... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Theres no power antenna....and I have no diagrams or anything to find the bose remote on...can I splice into any 12v that comes on with the stereo?
use the acc 12v coming from the radio, to find it remove the radio and look at the back or bottom or top of the radio and you may find a wiring diagram printed or taped there. if not use a dmm to find the lead that turns 12v + when the key is in the acc and run position. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
RcRacerDrew
RcRacerDrew
Carmel, IN
DARKHART
