hooking up leds
vtec_powah
hi im just about finished my custom enclosure and i want to add some leds, my question is, can i hook these up directly to the power on the amp?? and if so will it ever turn off or will they always be on, or will the lights turn of and on with the car??
you gotta be careful which LED's you get if you hoook them straight to the amplifier power. The amplifier power also varies as it need more power at times. so that idea (to hook it to the amplifier) is out.
If yo want to hook them into the power from your car, you should run a distrobution block (one line to the amps and one to the LED's) and get a switch for the LED leg so you can switch them off. You also need to get a voltage transformer if you don't get 12v LED's. If you use anything lower than 12, the tiny little filiments will pop right away and then you'll have wasted .79-5.99.
All in all, its a lot more complicated of a process than you think. Better if you bought a premade kit with instructions than to try it by yourself.
hey do it an easier way man i just hooked up a few also
i got a 30 amp really to run them and they come on when i turn my cd player on
it's really easy man
run a powerwire back with a fuse in it
use the remote off the back of the hu
ground it
and use the wire come out to for the power to turn everythang on and fuse everythang that you bring off of it
vtec_powah
vtec_powah
Montreal
couagajl99
