Hooking subs up to stereo.
you can hook up the sub to your system. your best bet would be to get a plate amp.
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&DID=7&CATID=25&ObjectGroup_ID=505
with most plate amps, you can use either speaker or line level inptus. in your case, if your system has a audio/tape out i would use those are the outputs to the plate amp. if your system doesn't have either, you can wire the speaker outputs to in speaker level inputs of the plate amp then back to your speakers.
remember this thing is in your house...so dont be sending it anything over 500w rms...
get a good small amp...like about a flat 500w max amp...or something higher if you like...but dont be pushing 1000w+ in your house...
...look at post above yours
i understand people using QSC and Crowns...but that much power in your house...i use 2 BK 12" powered by 500w...and all the windows are shaking...
i'm not saying that you just can't...i'm saying you shouldnt...
Everyone should be like lemans !
Put your hand in burning coals ...
Run your 4 ohm sub off your home receiver until it dies ...
Burn yourself with a soldering iron ...
Tell people 1/4 mile time is at least double the 1/8 mile time ...
Make a video of your sub and have a black guy pose as you ...
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif lmao
ChiefontheDitty
ChiefontheDitty
Sweetwater, TN
Decado
