Honda = Poo
ssj2xxgotenxx
The Chan Man
Just did an installation on a 2002 Honda Civic coupe, and I must say... it was the hardest installation to date. Everything was so complicated, and wasn't user friendly at all... Removing the side panels required removing a seatbelt bracket. Removing the headunit required removing a bunch of clips AND screws that required a really short screwdriver, which I didn't have. The engine bay is a rats nest and running the power wire was ALL bad.... Removing the rear seat was even worse... you had to remove a bolt just to slide it out. Very limited area to ground the amplifier... All in all Hondas in general are bastards... the Civic... I'll never touch one agian.
from now on im running my power under the car. and to whoever said they had an 18 in their trunk..what year civic? is it ported or sealed?
ever done a mid-90's S10? by CC's standards, you gotta drop the steering column to remove the dash. otherwide, you'll break off the hazard button.
that's a bish.
I had to take off the ENTIRE dash, drop the steering column, and a couple other things to install a deck in my dad's '95 Suburban.
I've only done Jeeps. They're easy.
Amen to that brutha. I installed a system in my old XJ, that was a breeze. And I just installed one in one of my buddie's XJ's. The entire install took probably about 30 minutes tops, including amp, wiring, subs, etc.
Matter of fact, I really miss my old XJ. That thing was AWESOME. 3.5" lift, 31" All-Terrains, lights gallore, oh baby. I'm pretty sure my next vehicle is going to be another XJ. They are VERY fun vehicles.... off-roading FTW!
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
M@nJo
