google much?
"The part above the cupholder that contains the pocket and the cig lighter, is the master key. It is held in only by plastic tabs. Use a butter knife and wedge it around until it pries off. Unplug the cig lighter and put that aside. Then if you look under there, there is a metal bar with 2 ratchet type screw in it. Those screws are STUCK on there! It took me like 2 hours to get them to start moving. There was a lock-tight kind of stuff on there. After you take those out, then the radio console comes out. Just use the butter knife again, and pry it out. Real easy once you get those screws out."
