Home receiver
It's an older Yamaha but I will check that out thanks.....is it bad to run the mids and highs threw the sun no right it's just turning into a huge mid sub
I have ran car subs off home receivers for deacdes. Sounds fine if you use proper passive crossovers. My garage has car coax in boxes and car subs in boxes ran off an older 2 channel receiver, through a 200Hz 12dB/oct passive crossover (2 channel, high/low). Sounds **** good.
A receiver with a LFE out requires another amp.
Plate subwoofer amps are recommended in all cases, you get active crossovers and good power.
Spldecendant
Spldecendant
Ny
keep_hope_alive
BP1Fanatic
BP1Fanatic
