Home audio sub box
skirch56
I recently aquired a logitech Z-5300e 5.1 surround sound. The sub in it was blown so i removed the amp and all required wiring. I then proceded to rip apart the box to see how it was designed. Well when i was done the box was pretty much a pile of crap. I was wondering what would be a good box design for two tang bang 6.5's. I plan on using the 100 watts rms that the amp allegedly supplied to the prior sub.
i've already seen specs, 70 watts rms, pretty sure last woofer was 8 ohm, so i figured buy two 4 ohm woofers, and wire them into 8 ohm, i realize they will be underpowerd, but i figure they would still kick the hell out of the stock one.
It's called TangBand, and I've got two of those little bastards sitting right next to me. Interestingly, they are finicky to get the most output out of them, so just take your time in the designing.
the amp from the logitech sub will not do shit. those amps are like 4 watts RMS and they hid the specs that show it. I bet it will be crappy with that amop. Buy a decent amp from pe
skirch56
skirch56
Shullsburg, WI
skirch56
