Ho do no good w/o baterry!?
rosrock
i just got off the phone with a store whos selling the 160 amp alt (80 at idle) and hes telling me that id need an optima battery, or something 1000? right now i have a duralast. Shouldnt this be ok? im running 1400 rms with the big 3 done in 4 gauge
He told you it isnt, is he gonna lie to you?? It isnt...at all...80 at idle is garbage and hardly worth the money. You wont see 160 amps until your redlining your car or **** near it. Save up some money buy a real HO alty.
He's hoping you will buy a large battery to cover the fact that alot of alt's are rated that high(factory) and it will not improve your situation because it's not really high output at 80amps idle
i only listen to music when im driving, u know 40 mph+ would that give me 140-160 amps? the alt is 130 shipped
o and chaos... u need to chill out brah //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im not trying to run 2000 watts... the most ill be running is 1400 rms, so are u saying a 160 amp alt wouldnt get the job done for 1400?
chaos... please no more answers from u, any1 else with a detailed opinion?
I know you dont want it...but Ill give you detailed.
80 amps at idle is enough to keep the car running, with everything on. Your amp at 1400 rms is pulling about 97 amps if it 100% efficient which it is not (no amp is) so that means you would need 160 amps at an idle at a minimum to keep everything cool. So thats 60 amps to the car and 97 to your amp which realistically would be higher due to the efficiency deal. Its just not enough, can you do it? Of course you can. Is it correct? No it isnt...Im sorry its not what you want to hear, but you did ask.
As well if you ARE going to buy it then yes buy a big deep cycle and it will bandage it for you, for a while im sure. Ill leave you alone now. :p
rosrock
rosrock
saginaw, mi
YoungBloodM50
BP1Fanatic
BP1Fanatic
