HO alt with only 1 battery?
srt4100
I am planning on getting a 270 amp alt from mechman for my 06 mustang. I was wondering if I could run just an hc1200 up front and be fine. I am using a fusion 2500 and trying to pull around 1300-1500rms. I dont want to relocate a batt in the trunk as I have no room. I wont listen to my music full tilt all the time. The size battery up front is very limited space wise so I was thinking an hc1200 or an optima yellowtop. Will one deep cycle batt be enough with a 270a alt?
You have to figure your cars needs in to this as well. You have to account for atleast 800 watts for the car. 1200 watts (support of hc1200) -800 leaves 400 watts of support.
"What Kinetik Power Cell(s) do I need to purchase?
Kinetik makes choosing a Kinetik Power Cell simple. Our model numbers are equal to the wattage needed for your vehicle. For peak performance and maximum lifespan of all electrical equipment in your vehicle simply add up the total wattage needed for all of your aftermarket equipment including all amplifiers, lights, winches, video and other electronics. The Kinetik Power Cell model number designates the amount of wattage it will be able to run. For example: your aftermarket system includes a 300 watt amplifier, a 200 watt amplifier and 40 watts of additional lighting. You have a total of 540 watts of additional power so you can run this system on a single HC600. If you are replacing your factory starting battery with a Kinetik Power Cell, you should factor in 800 to 1200 watts aproximately to run your factory equipment as well. If your stock alternator is 90 amps your factory electronics use around 1224 watts (90 x 13.6 volts). So adding an aftermarket system of 540 watts to your factory needs of 1224 watts would be 1764 watts of power needed. In this case we would recommend purchasing a single HC1800 or higher. If you plan to purchase additional electronics, you may want to factor them in as well. Remember you can always use more than one Kinetik Power Cell in your vehicle, adding addtional Power Cells at a later time is always an option."
Kinetik High Current Power Cells
****. My budget is really only for one battery. It makes sense though. If I were to get another battery it would be a 2400. Or could I keep my interstate up front and have a 2400 in the trunk?
Don't listen to these people. You have plenty with that alt. The voltage shouldn't drop to where the battery discharges so they really won't matter in this scenario. I don't know who audiolife is, but he posts like this a lot. It looks like he has a kinetik bias //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and a sales agenda. Sure if money were no object you could put 1 million kinetik batts on a trailer and pull it around and murder like hell. Instead, you have an adequately sized alternator and the only battery necessary is the one to start your engine. You're doing it right. Don't listen to these guys.
An alt that size should power a 1500w amp w/no problems whatsoever.
I think you'd be fine with an additional 500w comp amp as well.
No need to sweat this one.
One good battery (standard or high end) will work fine.
I'm running 1500w rms with a stock 110A alt and standard battery with only minor dimming at high volume.
I believe most people with comparably sized systems would report similar results.
So if I were to upgrade to a hc1200 or a yellowtop that firs under the hood, I would be fine with my current setup and can even add a comp amp (which are my plans)? I figured even if the battery were smaller, the 270 amp alt wouldn't let my battery die.
While the engine is started, your battery isn't doing anything. You're right the 270 amp alt not only won't let it die, it will keep it charged up nicely since it's not doing anything. Current is drawn from the highest source of potential (voltage) in a parallel circuit. What does this mean? It means your battery might charge up in the 13v range, but can only discharge very little current at this high of a voltage. The voltage drops rapidly and then it begins discharging heavily in the high 12's. While your alternator is on and the regulator can keep the voltage up at or above 14v, your battery is not doing anything. All current is being drawn from your alternator.
Ok then lol. Don't know much about electrical. Well I guess I'm goin with a deep cycle up front and a 270a alt. Just makin sure this is goin to be able to live up to 1500 rms load and a comp amp later?
Ok why don't we all run the smallest battery out there that starts our cars? Stock alt is large enough to cover the vehicle it is put in isn't it? Just saying I know quite a few people who tried to run cars off of a tiny battery and no audio system and the things like electric seats and air conditioning were ripped out. Those small batteries tend to fail in 6 months to a little over a year regardless if it was daily driven or not. If an auto maker could save money and weight by tossing in any old battery that just starts the car why dont they?
They do.
Literally nowhere in your incoherent ramblings did you even come close to a valid argument. I award you no points and may God have mercy on your soul.
Reallly? So in your opinin a group 34 or 78 is just any old sized small battery? You can go much smaller to start a car....
I don't think you know what you're talking about. My vehicle didn't come with a large battery and neither do most vehicles. They put whatever rinky dinky battery they can in there that will start the engine and run the radio with the engine off for a while. You cannot prove mathematically or scientifically that a battery is discharging when an alternator is able to keep its charge up around 14v, which it should in a stock system all the time. Until you do that, you fail.
srt4100
srt4100
atx
audiolife
