Hit an impedence snag
  • 4
GI JOEY
Paid 4 by ur tax $
Im in the middle of my build and noticed I ordered dual 4 ohm instead of d2 subs so with all 4 I will be at 2 ohms when I need 4ohms. So I will only be getting 1900 rms when I have over 500 rms more at 4 ohms. Guess I will have to live with my f up and get some dif subs or get another amp later. I was thinking about the sundown 3000d. But I also want to get some DC level 3's. Wish I pad a little closer attention to what I was doing.
JBL BPX 2200.1
2450 rms x1 at 4 ohms
1900 rms x 1 at 2 ohms
650 x 2 at 4 ohms
I think 1 ohm is like 1500 rms.
I jus thought about the imp rise though. If I am at 2 ohms at rest if I begin powering the subs I could see a rise closer to 4 ohms at full power. Hmmmm any ideas on this one?
not completely sure, but from what i read on a different forum, that amp is regulated like the jl's so it puts out the same watts at any ohm load, but i could be wrong
Well according to what I have read and heard 4 ohms gets its most power. This is an AB amp not a D like the JL's. I wish it were like that. I should have thought about this before I bought the subs. I was talking with another guy and he said he was seeing a rise to almost 8 from 4 ohms. So If I were at 2 and burped to almost a 4 I would be happy. He said hat I would be getting more power across the board being at 2 because the closer I get with rise to 4. I am not sure what I will see because of the box being larger than recommended. I can only hope for a little rise. Ill take whatever the box and subs give me. atleast I know I will never drop below 2 ohms and the 1900 watts. I bet there is a much bigger drop from 4-8ohms
JBL BPX 2200.1 2450 rms x1 at 4 ohms
650 x 2 at 4 ohms
You got the ohm loads wrong. 4 ohms should have more resistence therefore should not be more powerful at 4 ohms. 1 ohm load is the least resistance so therefore it will have more power. 2 Dual 4's can still drop to a 1 ohm load if ran parallel.
EDIT: Oh, I see your confusion. It's 2450 rms at 4 ohms bridged.
This is what I have found on this amp so far.
BPx2200.1
• 650W RMS x 2 channels at 4 ohms and
• Signal-to-noise ratio: 67dBA (reference 1W into 4 ohms)
• 2450W RMS x 1 channel at 4 ohms, 14.4V supply and
• 1810W RMS x 1 channel at 1 ohm, 14.4V supply and
• Dynamic power: 2940W at 4 ohms x 1 channel
• Effective damping factor: 6.28 at 4 ohms
• Frequency response: 22Hz – 302Hz (–3dB)
• Maximum input signal: 7V
• Maximum sensitivity: 250mV
• Output regulation: .12dB at 4 ohms
• Dimensions (L x W x H): 12-1/4" x 21-5/8" x 2-9/16"
This amp is odd. It has more power he closer you get to 4 ohms. So bridged at 2 ohms its only around 1900. Then 1800 at 1. I havent seen an actual birthsheet on 2 ohms though. I have been looking all freakin day.
I remember when the guy did the installation, he kept focusing on the loc, I remember him constantly talking about that and thats a piece he...
31
4K
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
Cool. If it came with a 2 year warranty from an authorized repair shop less than 30 miles away from me I might consider buying a few. You...
54
7K
GI JOEY
Paid 4 by ur tax $
GI JOEY
Amarillo, Tx
GI JOEY
    May 16, 2024
    May 16, 2024
