Hiss and shhhh sound :(
It shouldn't be making that much noise.....
Where did your source the 12V power for your head unit? If it is coming from an accessory wire or even the factory +12V for the head unit, it might be a dirty source of power. A good test is to pull the head unit out and run a wire straight from the battery to the head unit or from another power supply. You can also try a new set of RCA's while you're at it. If this doesn't fix it, then you know 100% that the head unit is faulty. I've ran into the same issue before with bad sources of power.
It's just plugged into the harness. However Crutchfield had me do it.
---------- Post added at 11:49 AM ---------- Previous post was at 11:48 AM ----------
pioneer hu for sure, mine does the same thing, even worse with ipod. Especially if you have your highs boosted past 0
Why do you still have that HU then? Which model do you have?
Don't quite have the money to get an 80prs at the moment, but my birthday is in two months. Also, my Focals have integrated crossovers. There is no crossover box, as they are built in to the woofer and tweeter. Since I have a Pioneer HU already, will the 80prs be a plug & drop (same harness and dash mounting equipment? I've never had another HU before.)?
Yep it's a pop and drop for the HU. As for the focal comps, they're like the HAT Imagine IIRC in that they have a built in stiffening capacitor mounted to the woofer. To go active with the focals, just connect the tweeter directly to your highs channel. If you're paranoid about not having the right kind of tweeter protection, PE has stiffening capacitors you can buy separately and just place in line between the tweeter and the amp.
My tweeters and woofer are all on their own channels already. Idk what the hpf is for the tweeters, but the amp only goes up to like 500hz or something, so the filtering must be happening just fine on the tweeters and whatever crossover is built into them because they sound fine.
Sounds like it's the stiffening capacitor, attached to the woofer. Basically has a preset frequency and slope (my guess is 2.2k@24db/oct)
How would the stiffening capacitor on the woofer do anything for the tweeters? They are not hooked together in anyway.
Its not bad, i can barely hear it, but my highs have a hiss when paused. Its a premier
Oh. Mine is pretty prevalent. Especially when I play something like a violin solo or something where there is only one main frequency at a time. Even during the violin solo my sub is making an audible hiss (low frequency hiss) so I'm guessing it's on all channels, which would mean it's the HU's fault, since I have two different amps for the comp set and sub, and also two different brands of RCAs for each amp.
Disregard... The capacitor's role on the woofer or tweeter is to limit the amount of frequencies the speaker will see. It is a passive crossover of sorts. It is usually good for 3dB/octave or 6db/octave depending on the design (1 or 2 caps).
I would limit the midbass to ~500hz or less. The tweeters should play from 2.5Khz on up. Although 3Khz+ is easier on the tweets. A 3 - 4" speaker playing at 500-2.5Khz can fill in the sound, but that would make it 3-way.
sjv13
StayStrange
sjv13
Lansing, MI
sjv13
