highly efficient 3k+ amp
Xprime4
****in' canadian
i might swap my old brutus 2006d with something else pretty soon, but don't have the money to upgrade my electrical for the moment.
i've got a 90amp alty, big 3 done, 0 awg to the back g31 batt (110ah) and stock 60ah under the hood. atm, with my current system, i never drop under 13v. I'm running the bxi200d at 1ohm.
if i were to upgrade for some more power, what amp should i look into? i'll probably end up buying more g31 later on... I never bump at full tilt for a long time, so a small batterie bank should get the job done. 95% of the time, i'm just blending the subs with the frontstage
any idea on what to get? efficient and powerfull (3.5k-4k) that can solid enough to stand some voltage drop over few secs....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif oh yeah on a budget too. say around 500$
Audioque 3500D for $549 shipped FTMFW!!!!!
Drew
yeah that model caught my eye... //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif are they efficient? rated at 14.4? underrated or pretty much dead on?
Just set your gain to where your not dropping voltage past 12 volts and you'll be fine. Just add a battey when you want more power, problem solved.
Drew
Yeah i'm taking care of my stuff.... i wouldn't let it drop under 12v. I'm alway monitering my voltage when bumping and making sure the amp doesn'T get too warm.
oh yeah, what kind of power can i expect at 12.5v @ 1ohm?
i thought the AP30001D was since they are $100 cheaper than the 3500 and only 500w less.
I tested one doin lil over 1,240w at 7.3 ohms so they are pretty powerful.
Haha big difference.... The aqx3500 is fan cooled will run at .5 all day long without getting hot,will burp .25, will accept higher voltages, clamped 3674 @ 1ohm and 3822 @ .5
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Xprime4
