High Volt Hu's
from what i have read the 8v Eclipse decks have great SQ.
i just got one today //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
probally will sell if the first dibber doesnt take it.
dont have to push em as hard to get the level of sound you want. so you wont be clipping the sound as easy. i think? mine sounds good!
mine is up for sale too!
higher voltage means you can run a lower gain setting on your amp. If you don't have noise issues with 3v (for example) you won't notice a difference at 8v.
You also have to be careful when running an 8v deck, because some amplifiers have a maximum input voltage of less than 8v.
I have set the gains on both my amps at ~33% with a 2v deck.
Overall, the noise floor is severely lowered because like everyone said, the gains on the amp don't have to be turned up as much.
As far as actualy SQ, the Eclipse decks used to have 55ohm output impedence on their 8v decks, not sure if they still do. Output impedence is more important than voltage when it come to actual SQ.
The deck I just purchased was the Premier DEH-P800PRS because it has only 100ohms and at 5volts. My gains are all the way down and it sounds as clean as anything I've ever owned.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
118
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
703
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
610
dj_yellaman
dj_yellaman
The Bottom
socaliguy81
audiobaun
    May 19, 2024
    May 19, 2024
