Hifonics
Originally posted by limitkid7 350X2 ISN'T THE SAME AS 750X1
its a 4 channel amp u can't do that
I HAVE THE AMP I SHOULD KNOW......
first of all i said 700w total...not 750. Second of all...most subs that hand that amount of power are Dual VC subs. so say you send each VC to each side of the amp...so u get 350 per VC.
Originally posted by limitkid7 ok - thank you
(not trying to be rude - just don't want false info being displayed)
np //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by andy00018 The HC's great, although Iam waiting on the amp (nine.1), I ran it at 600 watts on snova's amp and it got loud. Its in a 3.2 cube enclosure for now because thats all that i can fit in my trunk, (long story) and tuned to 35 hertz, but so far so good!
I'll have to second that the HC will get loud on lower wattages. I've got mine on 500w, and it got loud. 5 cube box ported @ 33htz. I'm getting a 1500w Visonik amp from RangerMan, so it should have plenty of power //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif.
Well... here are the specs on mine.
350 watts x 2 channels into 4 Ohms (stereo)
550 watts x 2 channels into 2 Ohms (stereo)
600 watts x 2 channels 1 Ohm (stereo)
1100 watts x 1 channel into 4 Ohms (bridged)
1200 watts x 1 channel into 2 Ohms (bridged)
Additional Features:
Full Mosfet operation
Stiffly Regulated Power Supply
4,2 and 1 Ohm Stability
0 to 18 dB variable Bass EQ
Fully Variable high/low pass/band pass crossover network
Variable Subsonic Filtration on 2 Channel amplifiers
Class AB Operation
Balanced Line Driver Inputs - .4 to 18V input Sensitivity
Gold Plated RCA Lineouts for maximum versatility
Fan Cooled Operation (Boltar, Zeus and Colossus)
Comprehensive On-Board Diagnostics
Wrap Around Brushed Extruded CAD aluminum Heat Sink design for superior heat dissipation
Discreet Transistor low level circuitry
.2volt to 9 volt variable Input Gain Control
Visual Diagnostic LEDs
Thermal overload, speaker short and clipping overload protection devices
Gold Plated Molded Terminal Block Configuration
u all are something else, i hope u all KNOW THAT!
when you give specs on an amp pls say what model number it is.... for example
hifonics z1000d - 400x1@4ohm/ 750x1@2ohm/ 1000x1@1ohm
hifonics z6400 - 85x4@4ohm/ 170x4@2ohm/ 340x2@4ohm bridged mono
for the z6400, the one u all arguin bout...
350x2 doens't mean that it will push 700rms bridged. and it prob wont.
i doubt you can even bridge the four channels man, you just got ur facts messed up bump
ws140
~`[]D[]][\/]][[]D`~
ws140
MA
Matador
