Hifonics ZXi 150.4 Big 4 channel
RRR37
Hifonics Zeus ZXi150.4
Like new in box with bass remote, wires, hardware and manual.
Specs:
CEA-2006 compliant amplifier
Zeus Series 4 Channel Class A/B Car Amplifier
RMS Power Rating (@ 14.4V):
4 ohms: 150 watts x 4 chan.
2 ohms: 300 watts x 4 chan.
Bridged, 4 ohms: 600 watts x 2 chan.
MOSFET power supply
Wired HFR-3 remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
2/3/4 channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, speaker short and DC protect)
Heavy duty aluminum alloy finned heatsink for maximum heat dissipation
Silver-plated unbalanced RCA level inputs
Silver-plated molded screw terminals
Input sensitivity:
Input Level (Balanced): 0.02V-6V
Variable low-pass filter (35-150 Hz)
Variable high-pass filter (10-15,000 Hz)
Crossover switch: HI/Full/LP/BP
Damping factor: >180
Frequency response: 10-45,000 Hz
Signal to noise ratio: 90dB
Dimensions: 21-5/8"L x 9-1/4"W x 2-7/16"H
Excellent condition
I mounted this once and ran it on my doors for about 2 weeks. Used this to push 2 sets of ID ctx65cs. I purchased a Sundown 200.4 on the black friday sale so I will now be using that instead to match all my other gear
$180 shipped.
Trades considered if favorable. Prefer cash. Paypal only.
I will ship triple boxed and padded through fedex.
i had the five channel of this lines of amp. will do rated. guranteed.
they sound good. musical, a little sharp on the highs, what the crossover is for.
never got hot.
good amp.
^^Thanks, I thought it sounded great on my ID's. Running them now @2ohms on a 125.2 while I wait for my 200.4 and they don't sound nearly as good as they did on the 150.4 @4ohms. If I had not got a great deal on the 200.4 I would be happy running this.
how do u like those ctx's? i may change from diamonds to ID, depending on how they do.
I love em. For $150 shipped a set I don't think they can be beat. About to add another set in the kick on my 125.2.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
807
RRR37
RRR37
Puyallup, WA
SMFJ
