hifonics olm2412 video
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
sounds pretty decent how the sql on that sub
sql wise, i can tell you its better than the btl, but it cant ever get as loud as the btl. pretty nice sub for the price.
is it just an extra sub u have aying around? or is someone letting u borrow it in the meantime.. either way.. its a nice back up sub anyways...
neat
i actually bought it just to test it out. i wanted to try something comparable to the btl, which the hifonics is suppose to be 2400 rms @ 1 ohm and btl is 2000 rms @ 1 ohm. actually pushing around 2700 rms @ 1 ohm to both subs, but i gotta say, hifonics olm2412 dont compare to the fi btl, even with boxes built to specs.
i don't think that power acoustik amp puts out 2700 watts rms if it does than wow i might get one lol
its doesnt it does close to 2200 at almost 18v... so you realy dont have more than like 1500rms if that...not sure if you've seen the test of that amp but it doesnt do ANYWHERE near rated power, not even at .5ohm
power acoustik sl-3400d, fuse rating is 150 Amps, it does a little over 2700 watts rms.
150 amps....
at an average of 12 volts....
means THE MOST POWER it can do is 1800 watts and thats with 100% efficiency...
figure 20% or so goes to heat drops it down to 80%
1440 watts is the most that amp can produce //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
150 amps....
peak right?
projectnutz
projectnutz
Arkansas
skateboardkid
vegang
vegang
