HIFONICS OLM-2412 or 2 Pioneer TS-W3001D4
gs300tx
Hey guys,
First post. Which would be a bette choice, I will be running the power acoustik 4000 watts( ps -4000d) which puts out 2200watts rms @1 ohm.
Here are the specs on the Hifonics olm-2412
12-Inch DVC Subwoofer
4800 Watts!
2400w RMS Rated and tested
For Ported or Sealed Enclosures
1-Ohm, or 4-Ohm Operation each sub (2 subs will run @ 2 ohms or .5 ohms)
76mm Dual 2-Ohm Voice-Coils
160 oz. High-Energy Magnet
Fiber-Glass Infused FEA Structured Cone
Die-Cast Aluminum Chrome Speaker Frame
Multi-Layer High-Temp VC
Front-Plate & Voice-Coil Cooling
Double-Laminated Integrated
Spider Tinsel-Lead Design
25.4mm / 1” Hi-Excursion Surround
Push & Insert Wire Terminals
Here are the specs on the Pioneer w3001d4
3,000 watts peak per sub
1000 Watts RMS per sub
4 Ohm DVC
Wide-Roll 3-Layer Fiber Radial Surround
IMPP Cone with Carbon/Glass Fiber Reinforcements
Aluminum Heat Sink
Titanium Voice Coil
Ceramic Coated Voice Coil Wire
Double-Stacked Magnet structure
Cast Aluminum Basket
Frequency response: 18 Hz - 700 Hz
sensitivity: 89 dB
Sealed Box Volume: 0.5 - 1 cubic feet
Top Mount Depth: 7.5"
Cutout Diameter: 11"
Thanks
gs300tx
gs300tx
Texas
1 Loud Explorer
