hifonics info
its says rms @ 1 ohm is 2600,
yeah... and unless your holding a full 14.4v+ at full tilt your probably not going to see a full 2600w. For the most part, the amp is over-rated.
If you can get a true 1 ohm load after imp. rise and burping it at 14.4v or above, you should see that 2500-2600w they claim.
so would this amp be any better then the power acoustik 3000db that i have now
i havent used any power acoustik amps, but they are slightly over-rated as well (from what ive been told and heard before).
your probably getting 2000w with good voltage out of the power acoustik. the Hifonics will make more power, but it might not be a noticeable difference just jumping up a few hundred watts.
If i were you, i would look around for another pa 3000db and run 2 of them, then you will have 4kw+ to work with.
jmkanek
jmkanek
Wise, VA
jmkanek
