Sold Hifonics BXI1610D mono subwoofer amp
nismos14
1. Product:
Hifonics BXI1610d
2. Specs:
# Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
# RMS Power Rating:
* 4 ohms: 550 watts x 1 chan.
* 2 ohms: 1100 watts x 1 chan.
* 1 ohm: 1600 watts x 1 chan.
# MOSFET Power supply
# Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
# Wired remote bass level control included
# Power and Protection LED indicators
# Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
# Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
# Dampening factor: >250
# Single-channel monoblock channel operation
# 1-Ohm stable
# Phase shift: 0-180 degrees
# Preamp RCA outputs
# Input level control: 0.04V - 18V
# Balanced line input for MX accessories and line drivers
# Heavy duty aluminum alloy heatsink for extreme heat dissipation
# RCA level inputs
# Screw terminals
# Variable low-pass filter (35-250 Hz, 24 dB/octave)
# Subsonic Filter (15-35 Hz at 24 dB)
# Frequency response: 35-250 Hz
# Dimensions: 14-1/4"L x 9-1/2"W x 2-1/2"H
# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
3. Description/Condition:
When it comes to class D monoblock amplifiers, Brutus amplifiers are truly the king of D class. Brutus BXI amps are considered some of the best amplifiers in the world and the new Super-D Class Brutus amplifiers reinforce that. The D-Class digital chip-set technology produces extremely efficient, low temperature, and a high amplification system resulting in a smooth digital to analog conversion with low distortion. The amplifiers stable at 4, 2, and 1 Ohm(s). All in all, that means that the amp will produce more output with less stress on the car's battery and charging system.
4. Price: :
$235 shipped
5. Pictures:
nismos14
nismos14
Jersey
nismos14
