Hifonics BX1205D
Coo that works
I guess i got figure out how to wire it to 2 ohms when i get my second SVC.
I know how to if there was only 1 + and - but now this kinda complicates things.
Im still a little confused on this matter
If i wanted to run a 2nd SVC sub should i just run each sub to its sepearte channel, but then i dont know if it would take it down to 2 ohms.
They're bridged internally, don't worry about it.
no they're not. It's a single channel amp - one in, one out - no bridging going on.
As Bballer said, they're parallel inside the amp.
There are two sets of terminals simply because with an amp that powerful you may be running 4, 6, 10...who knows how many subs, on top of that there may be multiple voice coils to wire. In some cases there may need to be several speaker leads from the amp - that is why there's 2 pair.
If you connect a 4 ohm load to each terminal the amp sees 2 ohms. Alternatively, just run one pair of spkr wires from the amp and do your parallel wiring from sub to sub.
"They're bridged internally" is the short version....
Hmmmmmm... so i can just keep it the way i have now which is 1st + and 1st - have wire running into them and do the wiring to the subs with 2 SVC's and then do my parallel wiring see a 2 ohm load.......
OR...
wire one sub to 2 terminals and the other sub to the other 2 and then it will see a 2 ohm load.
04blackgmc
04blackgmc
IL
04blackgmc
ThxOne
    May 13, 2026
