Hifonics Brutus BRZ1200.1D
temuchan
This amp has a single channel, but has 2 (-) and 2 (+) speaker outs. Should I wire to just one (-) and one (+) or should I wire both (-)s to one wire and both (+)s to one wire?
I read that the two terminals condense to one inside the amp, so does it not matter how I wire it? I didn't want to give it a dangerous ohm load by doing it wrong.
Sorry, I forgot to mention I plan on wiring two 4 ohm svc subs to this to present a 2 ohm load to the amp. My question is do I need to use both or should I just use the left (-) and the left (+)?
easiest way is just run one sub to left and one sub to right. will give you 2 ohm load
temuchan
temuchan
mville, MI
temuchan
