hifonics brutus 25th anniversary 2608d
  • 4
Jason19
1. Product: hifonics brutus 25th anniversary 2608d
2. Specs:
Brutus BXi Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2600 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Variable unbalanced input level control
Dampening factor: >250
Soft turn-on circuitry
Preamp RCA outputs
Stackable master/slave operation
DC, speaker short, thermal, and overload protection circuitry
Heavy duty aluminum alloy heatsink
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 15-35 Hz)
Dimensions: 17.72"L x 9.45"W x 2.52"H
3. Description/Condition: The amp is used but in great shape this thing puts out a ton of power and doesnt even get warm I had I had it running 2 sundown sa-12's running at .5 ohm and it was awesome never had a problem with this amp and does alot of power check out my video below.
4. Price: : 225 only
5. Pictures:
Here is the video
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Jason19
Jason19
Kenosha Wisconson
CAT MAN
audiobaun
    May 19, 2024
    May 19, 2024
