hifonics brand
I use two Hifonics amps.... the SQ is okay, the power is a little lower than they're rated, but for the money hard to beat.... although you can be in the same budget neighborhood with some proven amps like Audioque or Audiopipe perhaps....
so i take it that audiopipe and Audioque are true to the watts
Closer than Hifonics. If you have 3 dual 4 subs then you can wire them down to a .6 ohm load. An amp like My RD 1750.1 would be a perfect match for your application. it does 1750 watts rms @ 1ohm and is .5 ohm stable. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Audiopipe is a better budget amp for the money. And i have seen far less failure from them. But to be fair there are less of them in use, so time will tell. I have installed both Hifonics and Audiopipe, the Audiopipe seems to be the better of the two.
double a
double a
richmond,va
DBBOOM
