Hifonics and jbl subs
I have an Hfi1500d amp, and two JBL GTO1214d sub's. The sub's are 4 ohm dual voice coils and I have them wired 2 ohm each so on the amp it would be 1 ohm load. They are in a sealed box inside a Silverado. But to get any decent boom for the power the amp is supposed to have, I have to boost the amp and deck which I don't want to do. I've messed with all the settings on the amp and deck to no avail and even did the signal from RCA's adjustment with my fluke dv meter. I have the big 3 upgrade done on my truck with 2 gauge but the amp install kit I got was supposed to be a 4 gauge and says it is but its not. Its 6. Is that what is bottlenecking the system or do I just have to buy a different amp and 2/0 gauge wire? I Should wire it with a 2 ohm load though. The amplifier is supposed to have 1500rms at 1 ohm and 1000 at 2 ohm. subs are supposed to have 350rms and 1400 peak. Thanks for any of your help I appreciate it!
hfi amps are one of hifonic's junk amps. You are lucky to get 1000 watts at 1 ohm reactive load. Wired to 2 ohms, you might have box rise up to 4-6 ohms. That along with inadequate wire = next to zero power output.
He is wire to 1ohm.
But OP can u post pic of your amp settins like how u have then set? And what CD player do u have?
http://wrenchmonkey99.imgur.com/all/
Update: seems a lot better with the input level up more but isn't that going to make it clip if i turn the input up more?
They are wiring just like that crutchfield picture i have on imgur, Except for the amp has 4 speaker terminals so I connected the subs together on the terminals instead of sub to sub and then sub to terminals like in the picture. Assuming of course that the amplifier being a mono that they have the 4 terminals on it just for ease of wiring.
cd player is x8500bh pioneer. cds work better but i use pandora and spotify a lot too.
wrenchmonkey99's uploaded images - ImgurUpdate: seems a lot better with the input level up more but isn't that going to make it clip if i turn the input up more?
pictures are private.
wrenchmonkey99
wrenchmonkey99
Duluth, mn
wrenchmonkey99
