hifonics amps
Just get the one rated for more power. They rate their amps at 14.4 volts. Your amp probably will never see such high voltage, so just get the one rated for more power.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
196
faygo187
faygo187
Charlotte, NC
squeak9798
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
