Hifonics Amplifier RCA In-Outs
Trepkos
Ok My Titan Txi1008D has a RCA Line-Out and RCA Line-In ports.
I was wondering if I was running a cable from the Kenwood Excelon KDC-X791 which has 3 sets of 4 volt for Front,Rear and Subwoofer preamp outputs.
I was wondering if I could daisy chain the RCA cable from my amplifier to the two-channel amplifier controlling the component speaker system but which output would be idea for this?
yeah you can daisy chain the amplifies like that. just make sure you electronically set the gains so that the amps put out the same wattage. you could also just get Y splitters.
I don't think theres a way that a 1000.1 mono amp and Profile AP1000 amplifier can output the same amount of watts seeing as the mono amp is sending 500w to each sub and the 2-channel amp is sending 150w to each component system.
yes... if you wanted to only use one RCA from the deck to the rear then you would use either the front or the rear output from the deck...
if you want to be able to control your subwoofer level with the deck, then you need to have two seperate RCA runs from the deck... one from the front output going to the components amp and one from the subwoofer output to the hifonics amp
you can do it with just one, since the hifonics RCA outs are straight through from the ins.... you will just loose the ability to control the woofer level from the deck this way thats all
Trepkos
Trepkos
Mississippi
wesl56
