Hifonics 2610D Mono Subwoofer Amp
Joseph7195
Walkin Tall
Amp is in complete working order with minor scrapes and scratches. 8.5/10 aesthetically, 10/10 functionality.
It was used to power a couple RF T1 15's for a little while, but for the past year it's been used to power a JL10" sub at 4 ohm and a Cadence 12" sub at 4 Ohm. Upgrading to all Cadence so this has to go.
One of the negative speaker wire hookups is stripped. The other works just fine, they are both connected on the internal board, so it affects the functionality %0 , none. It's still a mono amp, so you just need one anyway
Specs:
Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
RMS Power Rating:
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2600 watts x 1 chan.
MOSFET Power supply
Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
Link & Sync feature allows the mono amps to be strapped or bridges via master/slave configuration
Wired remote bass level control included
Power and Protection LED indicators
Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
Dampening factor: >250
Single-channel monoblock channel operation
1-Ohm stable
Phase shift: 0-180 degrees
Preamp RCA outputs
Input level control: 0.04V - 18V
Balanced line input for MX accessories and line drivers
Heavy duty aluminum alloy heatsink for extreme heat dissipation
RCA level inputs
Screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic Filter (15-35 Hz at 24 dB)
Frequency response: 35-250 Hz
Dimensions: 17-3/4"L x 9-1/2"W x 2-1/2"H
Price: $300.00 Shipped and insured with tracking. Also I have a video after the pics that you can see it in working order.
Shipping will be USPS with insurance and tracking. Shipping is included in the asking price.
Video:
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
  • Locked
246
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
    May 12, 2024
Brendon Jenness
    May 11, 2024
