Tranquil
I bought a system off of craigslist. (First mistake)
I wired the 750watt amp with a 1400watt kit as it's all the place had (Second mistake)
The problems:
Everything seems fine. I drive a 2003 Ford Taurus SE... I ran my power cable from the battery (unplugged negative before I did anything) to my amp. Didn't plug it in, grounded my amp, plugged it in. Set up my speakers with a converter and ran them into the RCA inputs. Installed the subs with positive and negative in the right spots.
I don't know where my remote cable would be on a stock head unit, but I'm sure I could figure it out if I could get past this problem.
My fuses in the amp are blowing. Like crazy. Every time I connect the negative terminal. My ground should be fine, I sanded off the paint and connected it right next to the antenna on a bolt that's connected to the frame. I don't have any more fuses, I went through a box... haha //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Any help is much appreicated.
The problems:
