Hi guys. n00b here with a question.
dropmech
I happen to acquire a brand new Kicker C8 from a friend who never took it out of the box. I took it from him because it looks like it's a good free space sub for my 2006 Tahoe. I was going to fit it where the OEM sub would go if mine came with it. My question is about the amp. I'm just not sure what to go with. I have the stock HU up front and some kicker DS65 in the doors running off of the HU with no amp. The specs on the sub are: 30-500 Hz freq. response, 30-100 watt RMS, peak power is 200 watts, 4 ohm impedance and I'm pretty sure single voice coil. Can you guys help me out? Don't really have a budget in mind, just want to get the right equipment for what I have. On a side note, am I okay with no amp for the doors or should I look for an amp with those as well? The sound seems to be really good with it as-is.
If you're happy with the sound of the fronts there's no problem running them w/o an amp.
with a low power 4 ohm sub you can either go with a small 2 channel amp (bridged) that's 100-125w rms at 4 ohms or a small mono that's around 100 at 4 (prob won't find many mono's that small).
Here are some decent or better options:
I wouldn't typically recommend Jensen, but in this application I think this amp would be more than adequate: Jensen Power 400.2 2-Channel Class AB Car Amplifier
A little heavy on power, but nothing a low gain setting won't fix -- solid amp: Clarion XR2220 280W Max 2-Channel XR Series Car Amplifier
Another with ample power -- they just don't make many small amps anymore: Precision Power PPI S200.2 (S2002) 2-Channel Car Amplifier/Amp
Rockford Fosgate R150X.2 (R150X2) 150W Two Chan Class AB Prime Amp
Do your speaker grilles say Bose on them? You should have the Bose system since you have a factory subwoofer. I can believe you would be satisfied with the sound as it is now, but it will only get better as you replace parts. Even a new good quality head unit can make an instant improvement for the factory speakers and amplifier. I would do the speakers and amplifier at the same time though, not one or the other.
Thanks guys! I appreciate the fast response. Trumpet, I have the base, non-bose system. I mentioned the stock placement because the space is there for the sub. I just don't have one there, is all.
I see now it does say "if mine came with it". A 5-channel amp would be a good way to get 4 speakers and the sub powered.
What would you suggest? I'm running the DS series components in the front and the 2-ways in the back doors. I think they are rated at around 50-100 watts.
Precision Power P900.5 or BK580.5. A step up from these is the JBL GTO-5EZ. This one is the easiest to set up with the included test CD, and it has plenty of power if you ever change to a more robust subwoofer.
Me too and then I have to paddle anywhere I want to go.
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
dropmech
dropmech
Jacksonville
trumpet
    May 16, 2024
    May 16, 2024
