Hhheeelllppp!!!!!!! Asap
Bender
Okay, I have a 1997 Toyota Corolla. I had a Pioneer CD deck, had it ran to subs and all but got robbed and they pulled the whole thing out. I put in my stock radio again. (everything still ran). Just got some subs again, and a Dual Cd Deck now. so i cut my stock radio kit and tried connecting the colors to the dual and connecting all the wires again but it doesn work. so i put the stock back in and connected all the wires back exactly. It doesn work. What to i have to do to put in this aftermarket radio. its a dual. and the car is 97 corolla. ?????????????????????????
Dont ever cut your connectors off and just get the harness to match your car.
no you are probably going to have to go to the12volt.com and search for your cars wiring harness and hope you can hardwire it and if they dont work you will have to go to the junk yard or maybe online and get a new harness and wire it to what you cut off
1997 Toyota Corolla Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
dont forget to check your fuses
Bender
Bender
Cincinnati
ecko_0113
